steering wheel shakes (new rims, tires, allignment)!
    i was reading in other posts and people said that unbalanced tires, bent rims, bad alignment can cause this, but i had my rims and tires NEW since March 2007
    and i did the alignment right after i got them installed
    my steering wheel shakes at high speeds, above 50 mph
    what steering components should be checked out?
    and btw, my steering wheel shakes when i brake too
    but it only shakes when im brakeing hard from high speeds also
    probablly warped rotors
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    check the radius rod bushings... the bushings for the rod that goes from the from crossmember to the lower control arm. that will cause a vibration if they are bad.
    Originally posted by Devergote
    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
      my mechanic told me that that problem is because of my plus size rims, because the car wasnt built to hand such big and wide rims/tires.
      i dont really believe this because he doesn't have any experience modding cars
      MY CB7
        My car does the same thing. i thought it was warped rotors too. idk.
        OHIO CB7's
        My Ride
        MOD FUND: better if I could sell some of my stuff.
        Build Thread
        vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
          does it stay at 50 and then go away or just continue?
          you can check runout of the rim to see if it is bent.
            the faster i go, the more it does it
            and ive checked my rims, they arent bent
            they started happening a long time ago, even when my rims were new
            MY CB7
              checked wheel bearing?
                it could be your steering rack or radius rods.
                Every single cb ive had does this, some more than others. But mine always goes away when i go faster. So i just speed up,
                ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
                NE GUYS, Buy the last of my accord parts
                  HUB CENTRIC RINGS... This will probably solve your problem..
                  http://www.justforwheels.com/index.jsp?cat=hubcentric
                  Header Whorage and Official Part out sale.
                  Official Garage Sale Thread
                  http://jdmconcepts.com/ Head porting specialist..
                    I dunno man, that looks like something to counter the vibrations, and not a actual fix.
                    I can find my size bc i dont have aftermaket rims, which would mean that they are saying the rim is a problem. Im thinking this would take the place of balancing since most people dont wanna have those weights showing on their cool after market rims
                      if you got aftermarket wheels, make sure you get the hubcentric rings..
                      if you dont have aftermarket wheels, it could be that your rims are unbalanced, the tire itself has high/low spots, or your axle could be messed up..
                      I had a bad axle and had a bad vibration around 45-85 mph..
                        The more and more i think/look into mine, It was either bad.old steering rack (200k+) or my axles, which were never perfect. Ahh, goo thing i but in a newer steering rack and will be getting new axles as soon as my project will be done, then i will be able to confirm.
                          I forgot that.. my friends rack and pinion was bad and he had a bad vibration..
                            seriously, no one has said it in bold print.
                            your rotors are shot replace them and report your findings!
                            .............................-----------------93 Ex Coupe[/COLOR]-----------------
                            My CD7
                              Rotors have really have that much to so with anything unless he's brakeing. True they are wraped since they vibrate when braking, but i highly doubt thats whats causing the vibrations when just cruising,
                              PS, when i had wraped rotors, and I changed the whole spindle instead of rotors bc i didnt feel like dealing with the BS. I still had that vibrations crusing when my rotors didnt vibrate when braking.
