f20b part differences
    exactly what f20b engine parts are unique? i know some are regular h parts but some aren't. in february or march i'm gonna swap in an f20b and would like to be as prepared as i can fucking be
    pistins, block.
    Click sig to view MR thread
    Links to other rides:
    Honda Accord Euro-R
    Honda Odyssey Absolute
    Honda City I-DSi
    Honda Stream
      Well, the first thing you need to know is that this is an OBD2 motor.
      So, be prepared for the conversion.
        well i know the basic shit (pistons, cams, obd2, etc) but i'm mainly talking about replacement parts like the alternator, intake manifold, etc.
        i want the useful info for when u go to the part store
        also, do you use the electric p/s pump or the accord pump
          Ricky, there are a couple California guys with this motor swap done already. One is "AlmostJDM" I believe, can't remember the other. Get in touch with them.
            Starkrice is the one in Cali as I recall. AlmostJDM has the swap also but hes not in cali or last time I checked.
              well i've dealt with the swaps, i normally don't keep p/s but if i chose to i'd like to know whether the electric pump of the f20b will work or if the regular pump will bolt to the block, etc.
              mainly it's for when things start going bad and i have to replace them.
                just go to the link in my sig and youll be able to get every dohc and sohc f20b part if ya dont see it just email em and they will get you a price thats what i did for my pistons
                PSN ID's:Tidashoni
                1992 Accord EX Coupe
                My FS Thread
                Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                  obd1 h22 injectors/fuel rail intake manifold. header. alternator. distributor are all interchangeable.
                  if your gonna make an f20b obd1 just swap some of that stuff over and reprogram your ecu.
                  starkrice has an f20b. and swapped over some obd1 h22 parts to smog it and get it legalized in california.
                    the power steering pump issue is easily remedied as the wholes for the pump bracket are there, you just have to tap them like you would the trans. then use the prelude pump/bracket/hi pressure hose
                    but i've been known to be wrong about stuff like this.
                    Finally Up and Running. Numbers to Follow. Check my MR
                      ok since no one answered this question of yours ill answer 4 ya
                      valves
                      drivers side engine mounting spot its backwords(once i get my f20b out of the bay ill take a pic and show ya)
                      cams(sir-t and possibly sir)
                      connecting rods(no other engine from honda uses these connecting rods...that ive found)
                      iacv mounting spot (the bolt holes are reversed from the euro R h22)
                      theres more im sure but this is all i could think of
                      oh and the dizzy in an internal coil OBD1 dizzy
                      PSN ID's:Tidashoni
                      My FS Thread
                        SiR and SiR-T cams ARE different.
                        a buddy took out his SiR-T cams with the intention of swapping them for a set of Euro-R cams
                        and low behold, the SiR-T cams are similar in profile to the Euro-R!!
                        SiR cams are 'milder' compared to the SiR-T
                        thats from what he said. I didnt see it for myself tho
                        Honda Accord Euro-R
                        Honda City I-DSi
                        Honda Stream
                          yea i knew the sir and sir-t cams wer different but i just didnt know if the sir cams wer the same as the h22 base or type s cams
                          PSN ID's:Tidashoni
                          My FS Thread
                            Type s = Euro R. I hope
                            Honda Accord Euro-R
                            Honda City I-DSi
                            Honda Stream
