electronics/suspension cb9 to 93 prelude
    Got my self a prelude with f22a6 in it, just wonder if beside the obvious engine components if items such as the ecus, tcus and suspension spindles are cross compatible?
    89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
    94 Honda Accord 2.2 EX (Daily For Now)
    04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
    The vtec calipers are swappable to the cb7
      Pretty sure the lude has a different ECU, but I think it will work with a cb7 a6.
      What suspension parts are you specifically referring to?
        If u had the F22b dohc in the cb u can use the h23 ecu
          I have a extra set of cb9 wagon spindles, wanted to do a big brake swap to the prelude. The prelude has a a6 engine the needs a head. Just wanted to see what from the old cb9 stash pile I could use on the prelude.
            I'm assuming it was swapped to an A6?
            1993 Prelude S
            F22A1
            custom'ish turbo setup
            180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
            18psi boost spike = BOOM!!!!!
            currently being rebuilt
              Yeah, the A6 was not standard in those cars.
              And no, none of the suspension is swapable. If you've calipers from the wagon, you can put them on the prelude, use VTEC rotors, and have the big brakes on the prelude.
              You can swap ECU's and TCU's around with little difference.
                thanks, yeah I got the wagon calipers
