1. how is it so that a radiator cap help increase boiling point.. and when they say boiling point do they mean temperature?
2. okay the radiator cap have a certain amount of pressure and has a valve.. if its not sealing or the valve doesn't work what happens? car overheats because its not building up enough pressure to flow the coolant thru to cool down the block?
3. what happens if the waterpump builds up pressure more than what the rad cap can withstand..
