I was thinking about getting AEM tru time pulleys done on my car. Is this set-up good? I read on Royal purple's website that they gained 3.1 hp at the wheels on a 2002 F23 accord 4 cyl. So i was thinking about doing this. Any of you had good luck with pulleys? or is it a bad idea? I need my AC in AZ and my Powersteering.
AEM tru time Pulleys whats your thoughts?
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
I've been running the AEM true time pulley's all summer with absolutely no strains on my alt. AEM Alt and PS pulley's - I never did a dyno to see if there where any actual HP gains. Seems to get up in the RPM's a bit quicker. As I stated my stereo doesn't have any ill effects either and it's not a stock system. Lights don't dim nor do I seem to have any power related problems.
from me!
The AEM pulleys are fine with basic stuff. If you have a crazy system, then your alternator might struggle to keep up. Also, if you like to sit and blast that crazy system in a parking lot, the idle speed might not charge the battery enough. If you haul around a huge system, the minimal gains given by the pulleys won't be worth it anyway!
I have the UR underdrive crank pulley. I've had it for 3.5 years, and many many miles. Not a single problem. Others have said that it has caused problems for them, but from my experience, it's fine. The lightweight OEM size may still throw the balance off a bit. If you want to replace the crank pulley, and want to be safe... check out Fluidampr.
haha yeah i'm just trying to overcome the drag loss of having a roof rack on my car w/ a bike......you woulnd't believe how much that slows the car down at 70-80mph
update. i found this on Rywire.com while i was ordering some stuff for my friend. read the section about pullies. its #4
http://rywire.com/store/faqdesk_info...569cd921dd8d46
Originally posted by Vtechnoupdate. i found this on Rywire.com while i was ordering some stuff for my friend. read the section about pullies. its #4
