ok heres the deal. I think my thermostat is stuck open or reading incorrectly.
Before when it was warmer outside, he temp gauge was at middle, but not middle a little bit lower than the middle. Even when i was idling or going 90 mph.
Now that it is colder, it barley gets off of Cold. sometimes itll go up to 1/8th but thats the max it will show. Same thing as before idling or 90mph it shows the same.
I am thinking my thermostat is broken or stuck open. It could be stuck open pumping coolant all the time, which is good, but not for me bc this is supposed to be a/my ecnobox, and i dont want it to pumpo gas in like its cold.
Or im thinking that its just reading wrong. I know the engine isnt overheating or anything bc after just about each drive i check everything, and the engine is warm, but never overheating hot type thing. Im pretty sure i need to replace the thromostat, im not not secure enough to diagnose my problem myself.
Also if you want to tell me, where is the thermostat? I could probably figure it out, but ive never actually did anything involving the thermostat. Is it near the place you bleed the cooling system? or is that actually it?
