F23a1.......
    F23a1.......
    what is the effect of the f23 sohc auto 2.3?
    what do you need to change or you can keep. from the old 91 cb9 block.
    LIke:
    manifold/PGMFI
    tranny
    fuel system
    Ecu
    TCu
    or do you the down of this block.
    MY YOUTUBE Channel Plz Sub for the Support thanks
    ^^^ Click for the Link ^^^
    one thing for sure, the F23a is OBD2.
    Click sig to view MR thread
    Links to other rides:
    Honda Accord Euro-R
    Honda Odyssey Absolute
    Honda City I-DSi
    Honda Stream
      Wait are you swapping an f23 in your car?
      If you are you're going to need everything from an F23.
      ECU, Emissions, Intake, Exhaust mani, EGR, everything
        Good luck. Intake manifolds won't swap over and it is all OBD-II, so to get it to work would take some custom wiring.
        Gary A.K.A. Carter
        [sig killed by photobucket]
          Originally posted by blizzard335
          OBD2.
          i know what obd means but what is the 2 for.
            no its been done. i brought it form this guy. its was all fucked up.but once i got it shape...runin it for like 3months now the car is goin down hill.
            i had a guy look at the car once and he said," that not the f23 manifold, its the f22 one.".......
            like do you know what kind..
              I see one solution, use the OBD1 Head. I dont think you want to use the 6th gen trans since they seem to fail often. If you make it a franken motor replace alot of the gaskets and seals in the head. Later
                OBD-II
                Honda Accord Euro-R
                Honda City I-DSi
                Honda Stream
                  dude, it is economy vtec.
                      not made for performance.
                        btw...his sig pic is way too big.
                          http://www.cb7tuner.com/vbb/showthre...highlight=F23A
                          My Accord History:
                          91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
                          -Patrick
