vehicle emissions
    vehicle emissions
    i was wondering if anyone knows how strict the emissions test is for maryland. also do you have any suggestions on what i should do to prepare such as oil change ect.
    R.I.P. Cb7 4/27/05
    My members ride page
    Official Ebay Whore Crew #1
    Well basic tune up, new sparks plug, wires, distributor and rotor, run some fuel injected cleaner. Make sure u catalytic converter and that O2 sensor is working. That should be enough
    U silly rabbit don't u know tricks are made for kidz, You without me is like corn flakes without the milk! This my world, you just a squirrel trying to get a nut!!
      Depending on how many miles are on it, and what you've done fairly recently, you may not need anything. I know my car passed New York emissions with no probs and no work, and that's one of the toughest tests in the country.
      1 3 5
      2 4 R
        fuel injector cleaner a week or so before, and the day before, fill up on the highest octane gas you can find and take it on a nice high speed highway run before you go for the test
        MEMBER'S RIDE
        i was driving along today and the check engine light came on.
        i pulled over and looked under the hood.
        the engine was still there...
        ...silly light!
          okay so i failed my emissions test. after the test i changed my spark plugs, oil, check the cap and rotor (both looked fine) and used some fuel injector cleaner. I couldnt find a new air filter but im gonna go check the dealer tomorrow. Is there anything else i should do? Should i change the fuel filter?
          R.I.P. Cb7 4/27/05
            Okay i retested after changing my air-filter, spark plugs, oil, and i ran injector clean and high octane gas. After all that i got worse results than the first time! Im failling the NOx and HC parts of the test. Yes i did warm my car up first. Any suggestions?
            R.I.P. Cb7 4/27/05
              hc is distribitior cap and rotor
              nox is egr ports....
              maybe u just need a new cat...
              Retro!
              Hater
