im thinking of buying a relocation kit because i live in an apt building and i dont have anywhere too change my oil, and itd keep the filter a bit cooler. its the little things that add up.
i run k&n filters and they are expensive. BUT if you were running 2 filters....theoretically youre filters could last twice as long.....am i wrong too assume this?
In theory your filters would probably last, but your oil might not. If the oil stays cleaner you might be able to go 5k miles or so.
And why are you using K&N oil filters? Its not like they're washable and reusable. I hear great things about Wix Oil Filters, but personally I use Bosch.
only problem with more filters is more resistant. two wouldnt be a problem. and remember its not that they last twice as long. the first one is line is gunna get the same amount of wear and tear that a normal one would. and you still have to change your oil pretty frequently, oil has additives in it, whichare the real benefit besides lubrication. I personally change every 3k on the dot, but 5k isnt unreasonabe.
Proud owner of the only JJDM full 2.5" catback exhaust!
IF your small enough why dont you just pop it on the curb? Thats what we did with my friends stang lol. Anyway you should be able to use a factory jack to hoist it up that what I did when I lived at my Apts. Its really not hard and I aint that small either. Also the Universal GReddy kit uses an ae86 filter. So thats another hassle if anyone wants to use that one.
