Man this thing is pissing me off. I have a 92' EX 4 door w/ 93 H22a. Ok this stuff has happened within the past week and a half. First I was on my way to work and it died. I figured out the distributor rotor was melted. 2 days later it died again figured out that the distributor bearings were bad, fixed that. Then it was running like shit and had no power. I adjusted the timing with the distributor, ran fine for a day or 2 and then it started throwing me codes like crazy there was like 6 of them.
EGR valve (has been on since I bought the other car with the H22 in it)
IACV
VTEC pressure switch
Ignition Output Signal
Crank Position sensor
Cylinder sensor
So, I did some research. I found out that I could clean my IACV and EGR did that and reset the ECU. Now it only shows 2 codes.
EGR
the weird thing about the VTEC pressure switch is that my VTEC works. Anyway since I cleaned those things it really runs like dog sh*t. I can barely keep it running when I stop at lights. I changed the spark plugs and it still runs the same. WTF is the deal?
Thanks,
Will
IACV
Cylinder sensor
EGR
Thanks,
Will
