h22a p13 I/H/E no cat. No CEL. Used the Prelude and now the Accord EGR. I still get hesitation at low acceleration. Everything is fine when I accelerate aggressively and at WOT. Driving at a constant 2k-3k the car jerks sometimes and will rarely backfire. Same with low speed acceleration. I also randomly get a jumping idle 1500-1000rpm. What should I check now?
hesitation and slight backfire
O2 sensor can be slowly goin out on you. I know my o2 sensor is slowly goin out on me I ahve a shit load of mini backfires when I idle but no CEL.
Tru the hesitation in low RPM can be an EGR problem. I have a p28 didnt see he listed p13.
I'm having hesitation issues on my car (f22), you can test the EGR and its system with a vacuum meter, but you can rule it out by disconnecting the vacuum hose from the EGR, plugging it, then driving and seeing if the problem still persists.
I used that method and ruled out my EGR.
