car wont start
    car wont start
    ok i just did an f22b swap my car is cranking over but it wont start...any one got any ideas on how to help me out?
    you got spark?
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      ^ you getting fuel too?
      you have to check for spark and fuel...
      Air > Fuel > spark
      those three!
      but if its not starting...check all your grounds ( TRIPLE CHECK the thermostat housing ground ..and Valve cover ground )
      if in doubt....scrap the surface for a good contact..then retighten the grounds!
      check ALL the grounds!....ALL
      but if you're not getting spark: ( check )
      Ignitor
      Coil
      Ignition Switch
      Grounds
      plugs ( fouled )
      plug wires
      distributor Cap
      distributor rotor button
      FUSES
      if you're not getting fuel:
      fuel pressure ( clogged lines, Fuel filter, Fuel Pressure Regulator, gas cap)
      Main Fuel Relay ( points need resoldered )
      grounds
      Fuel pump
      Injectors
      Fuel injection resistor
      FUSES
      ** start with the easy things first mayne!
      did you set the timing before attempting the initial startup?
      TDC
      MR Thread:
        ^ definetly check the t-stat ground. when i did my swap forgot to put that on and wouldnt start so i was flipping out and started jumping to conclusions went and got a distributor which i didnt even need. so ya man goodluck on getting it going
          Air > Fuel > spark
          those three!
          Ignitor
          Coil
          Ignition Switch
          Grounds
          plugs ( fouled )
          plug wires
          distributor Cap
          FUSES
          grounds
          Fuel pump
          Injectors
          FUSES
          TDC
          that would be a good start if not basically all you need to check. its always something simple !!!
          Originally posted by Devergote
          A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
            not to be an ass, but those two sigs are beyond the limit on this site.
              so i found out my problem last week i went out side to find wats wrong with my car an i look at my back left wheel an there was a puddle so i put my hand in it an it was a gas leak so i just took my car to da shop to get that problem fixed an i took da plastic piece off an all my likes are rust so ill fine out wat else is wrong with it when it gets back from da shop in a week or so
                lines rusted...its coming from one of those lines coming from the pump ( under the black plastic cover )..jack up the car..take off the rear tire..( for more clearance )..and take off that cover...find exactly where the pinhole is..and cut that bad section off. ( using a pipe cutter )..go to advanced auto or autozone..and get 2 clamps...and HIGH PRESSURE hose...
                replace that bad section with the hose and clamps....
                NOTE:
                make sure you unhook the neg.battery cable...and take the fuel cap off!...to depressurize that line!
                easy shit mayne!
                thats how I fixed one of my CBs that had the EXACT problem yours did
                its its closer to the pump...you'd have to drop the tank..to get a better clearance of the line you're fixing!
                make sure..you have a friend to help you...if you drop the tank..to put it back in its slot..because the tank CAN and WILL get caught on the exhaust heatshield thats lining the underbody!.
                Happend to me
                I had to use a big flathead and shoehorn the tank back into its hole. ( Oh yeah )
                along the tank...theres little plastic clips that holds the fuel pump wire into place..make sure you dont crush those ( looking and observing the tank while its going into its hole/slot )
                MR Thread:
