i dont know why out of random my ECU fuse keeps blowing so i got tired and put a 30V fuse and it hasnt blown yet. its some type of electrical problem. Any idea what is causing my ecu fuse to blow ocassionally.
ECU fuse keeps blowing.!!!
is that the 7.5 amp one....check ur deck too...wires can be touchinWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by Alex13modECU fuse is 10V not 7.5, also whats the deck? and um wheres the ground on the water outlet?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by T3aM 83rDI had this problem once, I had cut my o2 sensor wires because I was going to replace it and as I was driving apparenly one of the wires touched something that gounded it and it blew the fuse.
I would say if you done anything electrical on your car recently, go back and check there first.
Anyway car sent to mechanic. Car not drivable. Only way car turns on is with a 25 fuse or 30. If i put a 7.5 one it blows.
