ok. ive changed the oil pressure sensor. ive changed the crank shaft seal. but for some odd reason i still have an oil leak. its coming from the timing side of the motor so it has to be one of those seals. ive tried cleaning the motor and then after driving it for about 5 or 10min, looking at the area to find out where the leak is coming from but to no avail.
now if the oil leak isnt bad enough my oil light keeps coming on when i start to slpw down. once i get to about 1,oooRPMs it(the oil light) looks as tho its stuggling to come on. shen once i stop it comes on and stays on while im idling. can anyone help me with this?
also for some odd reason my battery light its on also. i figured my altinator is probaly going bad b/c the car starts and runs normally but the windows roll up slowly and the turn signals blink slower than normal.
