TPS adjustment
    TPS adjustment
    I need some help..
    I just swaped a F22B jdm plenum and Throttle body onto my a6 manifold
    I installed my TPS of my a6 cb7 on Throttle body of F22B JDM considering this one did not have a TPS. is the problem that with the TPS of the of my a6 cb7 I cannot adjust resistance has more than 845 ohms and that takes a resistance of 1000 ohms is what TPS of cb7 and prelude is judicious being the same one? if not is that this I must buy another Throttle body? cause Honda only sell throttle body assembly...
    My Ride
    Jas Airbrush, Custom Paint.
    get a voltmeter
    remove the throttle body from the plenum. put the car on the ON position. check the voltage of the TPS with the throttle plate closed. adjust the tps by rotating it either way. the voltage should read .45V when the plate is closed
    tighten it down and reassemble. you should be good
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
      are you supposed to measure resistance? i thought it was just volts.
        just volts.
        Big 16g Turbo/H23 Head Swap/TSX Projectors
          in the manual they told to measure resistance to adjust the TPS.
          it should be 1000 ohms
          My Ride
            i did the .45V method on mine, and i've yet to have problems
            11.68 @ 127mph
            417whp/375wtq
            Sold: 8/2016
              Measure voltage at closed TB 0.45 V. You're manual is incorrect for TPS adjustment. At the driver side shock tower area in engine bay at the connector, you can back probe that connect red/black and green/white wire or just straight negative terminal/ground to measure the voltage across.
                yeah what they said me and TN_Accords just got the TPS cel off my car last weekend.
