ok so it has happened for a while now and i was wondering if any of you have had this happen to you ? when i get out of my car and take my keys and everything ... my car fan will come on and off at random .... ??? it is really strange and i was wondering what might be making it do it or what it is lol ... so plz help thanks all !
fan acting up???... PLZ HELP
Last edited by 91 DX; 09-07-2007, 11:00 AM.The local asshole, 19 years in the making and still not giving a shit
Originally posted by mj213Wait... don't you have a carbon fiber hood? You need to give your "bro" a cunt punt.
Originally posted by bizzyboiHe will defend his stance on raping his car to no end.Tags: None
Originally posted by 91 DXok so it has happened for a while now and i was wondering if any of you have had this happen to you ? when i get out of my car and take my keys and everything ... my car fan will come on and off at random .... ??? it is really strange and i was wondering what might be making it do it or what it is lol ... so plz help thanks all !
It should not come on and off randomly though, that is not normal. And it only comes on at 230 degrees, which is very hot. It will run a few minutes and then shut off.
This happened to me and it was the sensor aka switch for the condenser fan. It is the green colored switch on the top radiator hose inlet near the head.
You can test it out by disconnecting the switch and bridging the terminals in the connector while your key is out and engine is off. The fan should come on and stay on as long as the terminals are bridged.
good luck
Originally posted by ceelooboobfan timer unit...it went bad on my car and my fan would turn on sporadically like that...fan timer is beneath the dash on the driver side of the car.
There is also a switch near the lower hose inlet on the thermostat housing, which only operates the radiator fan while the engine is running. It somes on at lower temperatures.
NORMAL!
MY cb does it all the time, on cool days when i shut the car off, it doesnt come on
on hot days it comes on.
even on cool days when i beat the shit outta my cb, the fan will come on.
its liek a timer/temp sensor or something.**Blk Housed Slut Crew Member #1**
my car does the same freaking thing, so i actually have to wait like 5-10 sometimes (depending on how long i drove for) to set my alarm because i have it set to sense current draw and the fan sets it off. for the longest time i thought it was my door triggers.
but where exactly is this timer or whatever you guys are speaking of and whats the name of it so i can at least attempt to fix this because its annoying to have to remember to set my alarm after ive already gone in for the night.
thanks
Originally posted by 4CYLPOWER92I believe the fan timer unit only operates the fans when the engine is on, and should only operate when the A/C is on. So that was a different problem.
This is wrong. The fan timer also kicks on the radiator fan alone when the engine is off after its been running for a while, it also shuts the fan off after a certain amount of time. Hence the term fan timer.
The ac switch controls the condensor fan(4 blades) only. When idling at a stop light or sign BOTH fans are suppose to come , depending on your thermostat type, when the temperature hits 185 or 195 or higher.
If you are idling and only the radiator fan(5 blades) comes on then there is something wrong with the ac switch/circuit or the fan motor itself. If both fans dont come on the thermo switch, relay, motor, fan timer, fuse, or circuit is badLast edited by Fake Thug; 09-09-2007, 03:01 PM.
thanks
Originally posted by 4CYLPOWER92It should not come on and off randomly though, that is not normal. And it only comes on at 230 degrees, which is very hot. It will run a few minutes and then shut off.
good luck
