how many people have done timing belt with engine in the car?
    Just wondering is there enough room to see what your doing to line up all the markings with the engine in the car?
    there sure is, kinda tight, but definitely possible, i've done about two or three already
    THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
    My Ride thread
    Flickr
    Originally posted by d112crzy
    And it can only get better. That's the best part.
    All I gotta really say is:
    People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
      definitely lots of room
      the markings are easy to see, tho. pull out the plastic cover at the bottom pulley, take off the VC and plastic cover, and u can see clearly the markings on the cam pulley and crank pulley.
      good luck
      Click sig to view MR thread
      Links to other rides:
      Honda Accord Euro-R
      Honda Odyssey Absolute
      Honda City I-DSi
      Honda Stream
        yeah. ive taken my timing belt off with the motor in the car. actually was a WHOLE lot easier than what the shops always said. they always told me it wold take 2 hour to take off the PS and AC belt and then drop the motor down to the side then take the belts off. it took me all of an hour to do all of the that. bastards tried to charge me $800 just to do that and replace the seals. i would have done it in about like 3 hours but i was having trouble with getting the AC and altenator belt back on.
          IN the car. Just move most of the shit out of the way drop the driver side mount and tis there. Just need a light if your doing it in the dark.
            yeah my mechanic at work did it in about 1.5 hrs, and that was with other jobs going on.
              done about 12 timing belts and waters pumps along with all the seals and stuff all with the engine inside the car. not that hard, once you have done it this many times, you learn a few tricks and get it done faster. last one i did was timing belt and water pump and took me about 45 min from the time i started till the fans came on.
              and yes there is enough room to line up the marks and we as clearly see them. after you put the belt on, turn the engine till its a tdc again and make sure the marks are lined up
              Members Ride
                x2 when you take that mount out the engine tips down plenty and theres enough room.
                My Members Ride Thread
                  A mechanic friend of mine and myself did mine w/ the engine in the car, car was on a lift, wasn't too bad. Next t-belt job will be done by myself though!
                    same here on number 4 as i type
                      werd, recheck, recheck and recheck the marks. dont want to skip a tooth :o
                        For F22A's, it's complete cake.
                        It's more of a bitch for h22/h23/f22b dohc because of the dohc head, duh.
                        Theres like 1" of room between the valve cover and the strut tower.
                        I'm sure it's still doable.
                          Man to me it's very easy, it's just the crank pulley bolt that get's me sometimes lol!
                          99 GS300 (Aristo) 2JZ Power
                          Bought from:gdout, bb6-sh
                            Theres less room with a 5spd conversion done with the prelude mount. Id say its nearly impossible for me to do it with the engine in the car with the current mount setup.
                            To-Do List for Today
                            Be Awesome
                              Yea, you'll probably have to take the ps and alternator off for more room.
                              You probably won't be able to lower the engine, since it will most likely hit.
                              Sucks having fat hands.
