Polishing Plastic
    Polishing Plastic
    I know this has been discussed before, but nothing has ever been in stone. How would one go about polishing plastic? I've got two things; my Alpine crossover box covers have a million real light surface scratches, and my JDM headlights have one somewhat shallow rub across one light's surface. How about the clearcoat on those headlights...can that be re-done with a standard automotive clearcoat?
    I do believe there's some sort of buffing compound for plastics. wal-mart or pep boys may have some good products for you.
    I don't know how well it works for plastic headlights (since mine are glass) but I just detailed my car using 3m Fine Cut rubbing compound and meguiar's 3 step. Even did my tail lights. I think it came out very well!
    My best recommendation would be to get some 3M Fine Cut Rubbing Compound and a good polish compound. Try it on a small spot that isn't eaisly seen first (just to be safe).
      yuuuup
      i agree w/ pwrusr... 3m is the way to go. gets rid of haze and all. might have to put a lil elbow grease into getting out a very very very minor scratch. worth the try though. good luck
      O'skool fo sho! You might hate, but I been doin' this long before you know.
        This product is made by Maguires:
        http://www.ipdusa.com/ProductsCat.aspx?CategoryID=651&NodeID=2514&RootID =629
        I've used it forever and it has great results- not only on headlights but loads of other plasticy surfaces. Highly recommended.
          What about the Mother's mag and Wheel trick...I've heard it works really well...I've also used Scratch X (forget the company...maybe meguiars or other known detailing company), haven't had stellar results, but I did notice an improvement in the finish (shiny vs. dull) but no improvement in nicks.
            plastics use this:
            mequiars scratch x....
            its a white bottle, about 6 bucks.
            its neat good for any plastic, gets alot of the surface "light" scratches off...and really cool cause u can use it on the rear lights, bumper lights, corners etc.
            try that..
            it wont harm the lens either.
            Retro!
            Hater
              uhhh meguires plastx is a white bottle and
              scratch x is a black tube
