O2 sensor question
    O2 sensor question
    Is it possible to splice and solder a new plug tip on a O2 sensor and it work correctly?
    yes but there is no reason to splice and solder just pull the pins out of the old plug and use them in the new plug
    the build and demise
    buy stuff i want a new car
      hmmmm why didn't i think of that...
      yes it is possible. i have done it to my ex.
        solder doesn't hold well. and plugs were cut already....
          solder does hold well. but if you don't know how to, then it won't.
            shit all i did is cut the wires and put the new plug then i use head shrink. works fine.
              Solder is the best method ....solder then crimp ( OR ) solder and electrical tape it
              MR Thread:
