leak
    leak
    yesterday after i came from my friends house i scraped alittle bit coming out of her driveway and ever since then its been leaking right by the oil pan the belt on the left side of it and also a leak behind it but looks like powersteering fluid because its red but the other fluid is a browinsh red color so im not sure if i dented the oil pan but it still rides the same if anyone can help ill really appriciated
    tranny fluid?
      jack up the car and pin point the leak, wipe it off and then start the car or just let it sit to see where the leak is coming from
      Members Ride
        i dont think its that but it might be you know on the A4 where the belts are if you look on the bottom right next to the oil pan on the left side bu the belt thats where its leaking from and the the other leak is behind the oil pan
          okay i think it might be the power steering pump because it whines when i turn or if im sitting still and turn it vibrates and whines
