Wheel problem
    Wheel problem
    Im having a problem with my front passeger side wheel. The wheel looks like its warped when rolling but i know it aint so what else could cause it to wobble a little when driving? This only occured recently and i took the wheel off and didnt see anything wrong. Also made sure lugs were evenly tightened. Any info would be greatly appreciated lmk
    I-SR 6
    and you have no vibration?
    spin the wheel when it is jacked up in the air, check for play and runout
      Could be a bad wheel bearing. Like wed3k said jack it up and check for play in the bearing.
      I need a 14b or 16g turbo!
        check your wheel bearing....ball joints ( upper and lower ) and tierod ends! and/ OR bushings!! on that passenger side!
        did you hit anything....pothole...curb..anything?????
        give us details!
        ANYTHING that would cause a suspension part to get bent?
        MR Thread:
