IAB's stuck open
    IAB's stuck open
    So I know my IAB's are stuck open. I was wondering what sort of performance loss I'm having with this problem? I'm fixing it soon enough, but I've been running like this for a while, can any damage occur from it?
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
    Nope, just a loss of lower end torque. No problems though
    if you want, you can route that vacuum hose directly to the manifold until you get it fixed
      ...adjust accordingly
        I see you have a turbo...
        I think this situation might actually be beneficial lol.
        Originally posted by kc8enb07
        does it come w/ jdm trash? they better throw away gold in it
          How's would it be beneficial? If it is then I'll keep it this way, but if I'm losing lower end power then how is it doing any good? You might have a point, I'm just trying to understand
          SOLD!!
          Boosted H22
            its actually not beneficial since an operating dual runner setup beats losing low end.
              Oh, yeah if you're turbo it might be better to keep them open, because it will help maximize airflow. Unless you need torque when the turbos not spooled.
              If your turbo doesn't start boosting until around 4700 rpm, then they're limiting you.
              In fact, one of these would probably help more.
              These are cisco's pics, so credit goes to him
                So since my turbo spools at around 3500prm, you're saying that having the IAB's open isent limiting the performance a whole lot.
                SOLD!!
                Boosted H22
                  iab will just be a restriction in the flow of air. Just leave them off. You have the turbo to cancel out the need for iab.
                    check this thread out http://www.cb7tuner.com/vbb/showthre...5&page=5&pp=20
                    ^^^he gutted his intake mani and said his top end is endless...i agree for turbo to leave iab's open
                    or you can use this http://www.blacktrax.net/BTP_IMS.html ...it replaces the iab's with a spacer/iab delete
                    My Members Ride Thread
                      Cool thansk for the help and ceelooboob thanks for the links
                      SOLD!!
                      Boosted H22
                        ah, see I was hoping I had said something useful lol
                          i left mine open when i had it, just lost a little low end torque....but not bad. id say it starts to kick back in about 3300 rpm
                          i thought it being open was better for the turbo?
                          Retro!
                          Hater
                            Well we re-routed it to a vacuum line and now everything is fine. Went back out tuning tonight and although leaving the IAB's open isent all that bad, it really does make a difference with the low end power and I like it a lot more with it fixed.
                            SOLD!!
                            Boosted H22
                              is it ran off vacumn or is it on the IAB silionoid? cuase if its vac then once u put throttle it will open defeating the purpose
                              Retro!
                              Hater
