Tune Up
    Tune Up
    So I was talking to a guy about how my idle is rough, even in Park or Neutral (its more than just just shaky, its jerky too), He says do a tune up.
    So whats a tune up include?
    Also any ideas about the idle, Ive played around with the idle screw no difference.
    wat?
    A tune up is basically new spark plugs,wires,etc.You might also want to change the fuel filter while your at it.
    Project EP hatch on the way
      Also change all the fluids while you're at it
      SOLD!!
      Boosted H22
      375whp 298 ft/lbs at 15psi
        I plan to someday
        Also It seems like it takes for ever to start if the car isn't warmed up
        wat?
          Where is the fuel filter anyway?
          wat?
            there a series of vacuum lines that go into the TB, follow those back to the firewall and it will lead you to a black box. look under the black box
            as for the starting problem, id definitely check the ignition components.
              So its in the black box with the EGR stuff?
              wat?
                below the black box
                its a black cylinder about 4-5 inches tall, 2 lines leading to it
                  dont forget to check & replace your cap & rotor since you are doing the other things.
                  F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
                  Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
                  Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
