Yo!, well my car is constantly overheating, and I know its cause of the fan. I will finally be getting one tommorow. I know theres two bolts at the top of the fan, but even when I take those out, It still will barely budge. Are there any more bolts around the engine fan?. I checked in the Chilton manual, but no help there. ....
Engine Fan Removal
Two more at the bottom and lift up. The bottom ones you just loosen and the fan should slide out.
Originally posted by NAiL05Two more at the bottom and lift up. The bottom ones you just loosen and the fan should slide out.The beginning of a new era............................
