Background of the car:
1992 prelude with F22A1 from 92 Accord
H23 Intake- kept original fuel rail and injectors
eBay header/intake
WS2 exhaust
Around 220k miles on the motor
Fresh off a 5 speed swap
K, so when I accelerate I randomly hit basically brick walls in my f22a1 powered prelude. Anywhere between 2500 and 4200 rpm I'll be crusing along, then suddenly I loose power. It's significant enough to make the seat belt tensioners lock if I'm in 1st or 2nd, and when I get the power back one of the tires breaks loose for an instant. When I loose this power sometimes I get black smoke and backfiring, sometimes not. This problem is random and not really repeatable. I'm really confused because I've checked the normal stuff. It's only really been a problem since I raced it at Nelson Ledges a few weeks ago.
Here's what I've checked/done:
New NGK copper plugs
EGR blocked off (for diagnostics)
Replaced fuel filter
replaced FPR with another stock honda one
checked fuel pressure while driving... about 45psi at WOT, 39/40 at idle
checked for clogged cat
checked for clogged O2 (have new one, not installed)
checked for disty cap/rotor condition
checked for CEL- none except knock when I run a P14 (no knock sensor on car)
tried 5 different ECU's to no avail
coil is external and original to car (176k mi)
plug wires are NGK's, and disty cap/rotor that are about 12k miles old
Please help me. I've exhausted all of my ideas.
eBay header/intake
WS2 exhaust
