no start after swap
    no start after swap
    I just put an f22a1 in my old 90 cb7 cuz i had a shell and a motor and i need some money anywho when i go to turn the key click and nothing
    battery is good reading good voltage starter is good just had that taken off and checked at autozone cluch safety swicth is working all fuses are good main relay is fine as far as i know
    For some reason the ecu is not getting enough voltage the reason i think this is because the battery oil and engine light are really really faint they dont come on at all when i have the key on but when i try to turn it over i get the click and then the lights are just barely on the seatbelt light is blinking clear as day with all my acc on the lights the fans hazords everything else has plenty of juice but no start
    I want this car gone i need the money for my girls ring but i cant sell it if it dont start any help or suggestions would be greatly appericiated
    In the mean time while im waiting to hear back im going to redo some grounds
    thanks
    Make sure all grounds are connected.
    Main ones:
    -t-stat
    -tranny
    -from battery to chassis
    -starter
    Also, make sure the terminals are on nice and tight on the battery.
      Main ones:
      -t-stat
      -tranny
      -starter
      allthere and then some battery is in the back so i have fatter gauage wires and more grounds to compensate for the extra length drove this car before like this started up at like -20 no problem still same battery
        Triple check.
        Believe me, you won't believe what you missed.
          you say it clicks and nothing just a click
          starter trigger wire
          or starter power wire
          the build and demise
          buy stuff i want a new car
            Triple check.
            If anyone cares it ended up being some grounds not doing there job!
            lol 4 days spent on bull $hit
              Yup, exactly.
