i have a 91 4door f22b1 swapped cb7. nothing out of the ordinary no cat etc. i will be driving and all of a sudden the cel will pop up so ill turn off the car restart the car and its gone. it comes on at random times sometimes ill be driving for 2 hours strait other times just to the store 3 min away. anybody anybody?
check engine light randomly comes on ?
hmm..cel comes on randomly but DOESN'T shut off?....my guess is...
Need a new timing belt..
either that, or you could be having fluid running into your IM (Intake Manifold). Do you have a stock air intake/filter??
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Originally posted by Djmouahmm..cel comes on randomly but DOESN'T shut off?....my guess is...
how bout you check the code instead of making it go away by turning it off.
just cus the light went away, doesnt mean its fixed.
Originally posted by d112crzythe CEL doesnt come on when you need a new timing belt...duno where you got that from.
so i just jumped my cel and its a code 20 electrical load or somethin. whats causin that??? im stumped.Originally posted by jboycei f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
if its code 20 pop the hood check you fuse box there should be a white/yellowish sensor at the bottom right hand corner with 4 wires coming out of it the sensor may be bunt out or corroded you can clean it and if that doesnt work you might have to get another fuse box im not sure but i dont think that the jdm has a ELD in it so it should be fine after you clean it or get another fusebox
k im gonna go check that out right now ill post up what i find. thanks
edit: i just checked it out and is the fuse thing a 3 prong? cause if it is I dont even have one in it. on the bottom right hand corner of the underhood fuse box right?Last edited by 92cb7accord; 07-25-2007, 10:33 PM.Originally posted by jboycei f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
http://cb7tuner.com/vbb/showthread.p...&highlight=CEL
Its on the inside of your car. Under the dash, close to the door, passenger side.
Originally posted by d112crzyhttp://cb7tuner.com/vbb/showthread.p...&highlight=CEL
?? did you not read the thread?Originally posted by jboycei f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
