Hey guys i have my 91 accord and it won't start. It acts like its not in park because it doesn't want to release the key either it takes about 20 min of scewing with the key to get it out of the ignition but i have to get this car running for work pls help
Help!!! Car won't start
Put key in the shift lock and press down on the key and put the shift in "N" Then move the steering wheel to see if it isn't in the locked position. Try starting it if the steering wheel is unlocked. If the key still won't move...IDK.. Check all connections and fuses. Make sure doors and trunk are closed.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Hey! Did my answer work? I'm not even sure if I'm right. Had that problem on my coupe and it worked.....steering was way locked and had to force it to finally move and then the key worked.
Sometimes you gotta wiggle the wheel for it to slide out. If that doesnt work could be a bad ignition switch or that one sensor in the center console is acting up forgot the name at the minute.
