Ok, so my neo is freakin out. The problem is that I'm not sure which pressure sensor thing it is. like I know it is pr-6 so I use pressure, but then you get an option of in and out numbers so do I put in 6 and 6 for in and out. I'm confused.
Would you care to explain whats the problem...Just a sensor problem isnt describing much. For Hondas usually its 6in6out for the vafc. DO you have a manual I would read it over if not dl the pdf off apexi website.
