Bent valves on a new head??
    Is there a way 2 check if the valves on a head are bent?? I found a good deal on a h22 head and i would b pissed if i bought it and the valves were bent... Is there a way 2 check if the valves are bent without ne machines??
    DA FASTEST ACCORD IN QNZ
    The H-series potential only begins where the B-series ends.
    83 Porsche 944 Black - Sold (my first)
    91 VW Jetta GL Red - Sold
    95 VW Jetta GLS VR6 swapped Green - Sold
    90 Accord EX 4dr Navy Blue - Sold
    91 Accord SE Gray - Stripped N Junked
    92 Accord 10th AE Green - Sold
    93 Accord LX 2dr Frost White - 4 sale
    90 Integra 2dr JDM B16 White - Sold
    93 Accord EX 4dr Black - New Toy
    Yes, there is. Make sure all valves on one cylinder are closed, and then, with the head upside down, put a bit of water in the chamber. If it doesn't leak, or only leaks a little tiny bit, the valves are fine.
      or just use a flashlight in a dark room/shed...light shouldn't shine through
      ....and on the 7th day, deevergote rested and called his mom.
        Turn head upside down, And use Windshield washer fluid to fill the valve dome, Its blue in color so you will see it better than water. And its thinner than water so it will go through any imperfection in the valve area.
          do a compression test
            every single advice these guys have given you is GREAT....
            OR...you could always...like I PMed you earlier about....you could always take the valves OUT of the head..lne them up with valves from a junkyard thats straight...and see if the stem is bent as compared to a straight one!.....but you're overall bet is to do what everyone suggests........OR lay the valve down on its side...and roll it....if you see the stem go up and down while its rolling...its bent!
            92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
            MR Thread:
              windshield washer fluid IS mostly water. molecularly speaking, the difference is nil. MOST brands are 90-97% pure water anyway and the cheap shit from part stores is 99% water
