Fuel Injector Question?
    Hey im not sure if this needs to be moved to other automotive or not. Just let me know.
    Anyways, I have a friend with a 95' civic Si "D16z6". Anyways we are going to boost it before school starts and most of the work is pretty much up to me on this project and the last thing I want to do is mess up his daily driver.
    So after reading up a little about putting the DSM 450cc injectors I realized they do not have a resistor box like we do in our accords. There are two ways we can do this, the first way is to wire in a resistor box, but the cheaper and easy way is to put 10OHM 10AMP resistor in line per injector. This is the way that I am planning on doing it for him since I am not "TOO" advanced on electronics.
    My question to you is will the resistors in the provided link below work? I know they say right on them 10OHM 10AMP but I want to make sure I have this all correct so everything goes smoothly.
    Thank you very much and sorry for the useless added info
    http://www.radioshack.com/product/in...entPage=search
    The sig name is new from a local forum. sorry to confuse anyone.
    My Member's Ride Page
    The Accords gone but I will forever belong to CB7Tuner
    Yeah that'll work but in all honesty it really isn't a clean way to do it. I've done countless resistor box installs in vehicles and it's really a lot easier then you may think esspecially on that car.
    Just go to you're nearest upick and get the resistor box and pig tial from any Accord. On you're freinds car the injector wiring terminates on an 8 pin terminal on the drivers side strut tower. Remove the plug the links all the wires together and that will isolate all the wires. Then just use a multimeter to tone out each individual injector, when you find them , cut those wires off of the 8 pin plug and connect them to the resistor box, one to each red/blk wire of the resistor box. Then take the one yellow/blk of the resistor box and connect it to any of the four wires from the 8 pin plug that used to go to the injectors directly. Use heat shirk and loom and you can dress it up and make it look really professional.
    Does that make sense?
      Yea im pretty sure I get it, I have read up how to do the box many times, but im set on doing it the simple resistor way. Thanks for the info though
