Replaced throw out bearing, clutch and pressure plate now...
    I still get a whirling sound till I push the clutch to the floor... New transmission?
    Grinding when shifting and all that??? You using the OEM or aftermarket TO bearing...Sounds like the To bearing still bad lol.
      I get that same noise and it's only when I'm not on the clutch pedal. I just did a complete engine swap and also, a brand new clutch kit and it's still there....I think it's the tranny.
      I like my women like I love my cars, built for comfort and speed........
        lol same here
          No grinding when shifting.
            Is it loud? When I had my LuK OEM replacement I used the TO bearing with the kit. It would have a low pitched hum sometimes. So it was most likely the shitty TO bearing they make. Now with OEM honda dont hear anything at all with my xtd stage 3.
              Its pretty loud... Same exact noise as before I replaced everything
                Did you do the job yourself or get someone else to do it? It would suck if they put the same one back in =O.
                  This happened to my in my old Toyota pickup... I replaced it 2-3 times before I got a good TO bearing in there... friggin cheapo auto zone parts.
                  also if your clutch is not adjusted on some cars it can slightly touch the fingers on the clutch, and that makes the spinning noise when the clutch is disengaged
                  GL to you! I hope you can figure it out!
                    ^^ Could be bad to bearing from product too. I havent seen one go bad yet lol so didnt jump to that. But if you do any clutch job I recommend using Honda OEM TO bearing. Buy one and compare it side to side to what you use it is completely different.
                      I did it my self..... I realy did not want to take this apart again besides the noise will it cause future issues
                        Are you asking if it will cause future issues?
                        YES....AND NO
                        You need to figure out what is making the noise.... you either put a pad part in there.... or what is a better possibility is they may have given you a wrong part( meaning that it fits, but for some reason it is to tall, therefore laying on the fingers....)
                        if that is the case it will lead to premature failure of the TO bearing, and possibly the clutch as well..
                        it could be something more serious... I am sorry to say but you are going to have to take it back apart most likely, to figure out exactly what is wrong.
                          Annoyance thats bout it. And when you remove the trans you will prob have some worn fingers on the pressure plate.
                            I car has been running for about a total of 2 mins.
                              my z has that problem, i been told its a bad input shaft bearing in the transmission.
                              Retro!
                              Hater
