help real quick
    help real quick
    what size is the axle/hub bolt?
    36mm
    Finally Up and Running. Numbers to Follow. Check my MR
      Originally posted by mayberry4thgen
      36mm
      Yup 36mm
      U silly rabbit don't u know tricks are made for kidz, You without me is like corn flakes without the milk! This my world, you just a squirrel trying to get a nut!!
        you talking about the wheel studs or drive axle nut?
          It's a bitch to take off too...
          I'm sure everyone who's taken one off has some broken tools to show for it...
          You'll have a new found respect for the breaker bars that don't bend or break though...
          think of it as a tool challenge...
          I'm always amused on some level when I break a breaker bar... they are breaker bars after all...
          RIP Lifsatrip7
            rent a tool from autozone they do wonders the air powered drill and the axlenut bolt.
              not me..
              i guess it pays to have multiple friends with compressors/impact guns..
                werd....haven't broken a tool on them yet...break out the 350 lb-ft impact gun on the highest setting and compressor at like 110 psi.
                  thanks for the quick replies all.....
                  yeah i finally got them off today.......broke 3 breaker bars on it....1 craftsman and 2 "great neck" i got pissed off.....got the dremel and cut them apart......muahaha
                  but the accord is getting some nice pieces....
                  2 new axles
                  2 new rotors
                  new pads
                  master cylinder
                  sparkplugs
                  wires
                  some shady mechanics did timing belt on it and it was off a tooth so i fixed that and she runs like a dream now....yay
                  better get back to work on it
                    yea...i think i have same prob with timing belt issue....any tips? I have to reset the cam timing as well....
                      lol i also find it ironic when i broke my first breaker bar,HUSKY tools suck, but the lifetime warranty worked out. btw i kno all about the air tools, SNAP/ONS where its at
                        all i did was take off the timing belt upper cover and i pulled the timing belt off and held it tight while i turned the cam with a wrench with the other hand......then i forced it back on
                          that sounds iffy....did you ruin the timing belt? I was planning on releasing the tension on the belt, then doing that.
