swapping head components
    I have a h23 head with no rockers, cams, or cam caps. it has good valves.
    i have another h23 head with bad valves, but has all the components on it.
    can i swap all the parts over to the h23 head w/ the good valves?
    or bad idea?
    seems even majestic honda wont sell the cam caps seprerately.
    so i dont know, what you think?
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
    personally, id check the guides to see which head to use. also check the seats for pits and stuff.
    seats and guides are not entirely expensive to replace but just needs to be sent to a machine shop. at that point you might as well have them cleant he carbon and surfae the head.
      or bad idea?
      I don't think that will be a problem. just don't reuse the bad head.
