overheating problem...
    well my sisters car has developed.. a new problem lol...
    the car likes to over heat.. heres the breakdown
    fans work
    always has coolant
    temperature drops if u rev to 2k or so and hold it
    when moving it never happens only when stopped
    raises and drops quickly between being stopped and moving as in.. when ur stopped its 3/4 way up.. but when u start going within a few seconds it will begin to drop back down to normal temperature
    what could it be???
    my guesses..
    1.thermostat
    2.water pump taking a shitter
    what do you guys think? im thinking about flushing the coolant system today or 2morrow..
    thanks..
    C-los
    Praise The Lowered...
    thermosat! w00t
      just do a little search about this kind of things then if u not happy with what u find then ask.
      i had the same problem as u are having here it is what was wrong with it.
      http://www.cb7tuner.com/vbb/showthre...&threadid=7783
        first thing that poped into my head was, the water pump, it could be the thermo, but one thing is, do you have any oil in the coolent?????
        ^sold
          well, if the temp drops when you the rpms increase, then its more than likely the water pump.
          00 Jeep Grand Cherokee 4.7 V8 4X4
          92 Honda Accord LX
          95 Honda Civic CX
            Drain and flush it first, then change the thermostat. Those are cheap. The water pump will be $300ish, because you have to tear apart the front end of the engine. If it comes to that, the timing belt is an extra 30 bucks, and I'm sure you know the consequences if that belt breaks, so you might as well do that too if it comes to that. Sorry about the problems, dude.
            1 3 5
            2 4 R
              i would think water pump at first. but try the theromostat its probably that
              cb7 sold
              2002 mineral gray mustang gt not stock
              95 accord lx daily driver
                well check under the car. see if u find any leaks from the water pomp. other than that u got other stuff to check. just go by the add that i gave u
                  yeh .. thats the plan.. flush it.. new coolant then.. thermo.. if that fails.. ill fork over the dough for the new Water pump and T belt = teh ghey.. oh well
                    is it really overheating? i mean, when it says it does, do you check under the hood? cuz it could be temp sending unit buggin out on you, but you say the fan works.... odd, prolly is the thermostat, but just an idea about the sensor....
                    CB7tuner.com Appearance Specialist - PM me with any bodywork questions
                      Did you check to make sure you don't just have a very persistent bubble in your coolant? Did you bleed the system when you filled it up (if you changed a radiator, or were really low on coolant at one point for some reason or another)?
                      Always try simple things first . . .
