Right now my car is having two problems that are furstrating me and need some input on.
Problem #1
This is the more problamatic and confusing of the two. From time to time the car will randomly act sluggish and feels as if the car is pulling back power ( such as when you get a CEL for ur K/S). I have no CEL of any kind and the problem will disappear just as fast as it appeared. Also, if this helps any, if im doing a WOT run, when shifting into third gear the rpms like to bounce at the vtec crossover point for alittle bit as if im hitting a limiter and will just continue to climb in the rpms.
Any takers or is this too broad of a description?
Problem #2
this problem also happens time to time but I feel as if it may be an exhaust leak
Whenever I do a WOT run, once I reach alittle over 4500 rpms, there is a loud hissing that kicks in. Sometimes it is non existent, sometimes its noticeable, and than other times it is flat out loud ( the hissing).
Can this be an exhaust leak although it is not consistent?
Thanks for any help in advance, these problems have been bothering me for alittle while and any help is really appreicated
Problem #1
Problem #2
![wave](http://www.cb7tuner.com/wavey.gif)
