quick question on little black box on H22
    ok quick question on the bottom of the intake manifold is a little black box. Is it for the cruise control? there was a sensor plugged in and a vacume line coming out and another spot for a vacume line that was broke off.
    ITs for the secondaries in the intake manifold. You wire it to the ECU.
      its for the dual runners.
      "This truck is 100% sh*ts and giggles."
      "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
      You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
      Disregard females, acquire currency
      BUS 62 AIN'T F'ING AROUND!
        alright thanks
          ok so the box is all busted up and the vacume lines that were coming out of it missing or broken. I am guessing it was never hooked up so do I really need to put it back on?
            The engine will run just fine without it and you won't get a CEL. You will however be losing torque in the lower rpms and power in the higher rpms.
            ...adjust accordingly
              thanx I plan on replacing it as soon as I can find a perfectly good one to replace it with but for now I am going to get the head back on after the port and polish and the new header to give it a test run
              ordered new gasket kit and header + test pipe today
