Ok, here's my dilemma. My car's a retard. It will start up just fine, and I'll be driving down the road, and all of the sudden, the car will just die, or drop to 400 rpm and misfire REALLY bad (sounds like a semi with the engine brake on, just not as loud), and throw a check engine light. While the check engine light is on, it will absolutely refuse to start. Once the light goes away (randomly) it will fire up again, just fine. It does this quite a bit, and it's completely random. I pulled the code and it was throwing 14 and 15. 15 is Ignition Signal Output. Also, alternator is fine, it's getting fuel, battery is charged, all that good stuff.
Which do you guys think it would be? The igniter, or the coil? Or something else? It's really starting to tick me off...
