can n e one give me a step by step procedure on how to take my signal lever out of the steering column....
help me take this shit out!!
It's not an easy procedure. My friend did mine last year when I wanted to replace my signal lever and he had to remove whole steering column. Basically the plastic part that's attached to your steering column has to come off, but it is a pain in the ass. Why are you wanting to do this anyway?
Might not be the lever, turned out mine was a wire uner the steering column that was touching another wire which was causing all sorts of problems. When did this problem start happening? Mine started happening after we had to remove the dash including the steering column to change the heater core. The wire wasnt grounded properly and I bought a new lever but it was useless
