Shifter feeling funny not lining up or something?
    the search is horrible now for some reason
    im pretty sure thiers a diy on this. but
    my shifter feels wierd as shit its loose and seems like it wont go into 2nd, it doesnt pop out, but its hard to get in any gear sometime, and its going to ruin my tranny if i dont fix it,
    i cant shift fast at all anymore, 1st to 2nd takes forever. sometimes it gets stuck in gear/
    everything looks fine on the tranny im pretty sure it just needs adjustment...
    can someone point me in a direction here.
    also im going to be picking up a prelude shifter... so maybe this will help.
    looks like gloryaccordy had the same problems
    http://www.cb7tuner.com/vbb/showthre...=shifter+cable
      This may sound dumb but have you checked the clutch fluid level? It can make it harder to shift if the fluid level is low.
      ...adjust accordingly
        check ur shifter cable bushings....and shifter cable..also take off the center console and boot and see if it anyhting with the shifter its self.
        My Members Ride Thread
