ok si a while back i did change my master brake cilinder. i tryed to bleed the air out. well the car will stop only if i push the brake pedale all the way in the end. if i do press it all the way in the end i will stop the car. i was getting anoyed on why is it doing that, eventhough i did bleed the air out.
one week ago i changed a brake line. since i was there i tryed to beed the system again.
needless to say that after 2 hours and 3 big bottles of brake fluid its still the same. the car won't stop till i press the brake pedale to the end.
when the car is off and i push the brake pedal, that won't get hard as it does iwth my other accord.
the way i do to bleed the system is that i open all the little bolt things at the wheels. let it bleed for a little bit while adding brake fluid. then i start closing up the brake valves from the furtherst one and end up to the closest one to the brake master cilinder.
am i doing anythign wrong with this?
any suggestions?
help me out guys. this thing i getting me pissed off.
any suggestions?
