idle surge on a f22b
    My car is a 90 Accord with a f22b in it, and a swapped in JDM 5spd. When it was first finished, the car had bad idle hop due to a bad brake booster. I know it was the booster for two reasons: removie the vacuum hose and the car idled completely fine and the fact that i had little or no brakes. I bought a booster (cheaped out and went ebay), out it in and it still does it, but its different. Now the car idle hops bad (500-1500) when its cold outside and stops when its warm outside. If i listen to the booster area after the car is shut off, you can hear a leak, but only if the booster vacuum line is hooked up. If I unplug the IACV, car idles ok but obviously throws a CEL. Any ideas? I'm thinking its the booster again, but i just want other opinions before i fork over the cash for a honda one and do all that dam work. Thanks guys, sorry for the novel
    When you mean cold outside is it only idle then when it warms up its ok again?
      no i mean if its cold outside it does it all the time, but now that its warn it does it A LOT less.....
        try your im gasket o have a f22b and i put a new im gasket it on and mine stop doing that.
