Ok, when my car is at running temp-I will turn it off and back on, it will idle 1000-1400 jump mabye 5 times, and then steady out at about 1200.When Ijust tap the gas it will to the idle jump about 4 or 5 times and steady out again.It does this every time I touch the gas.
Alright well this is what I have done so far----
-Cleaned the IACV and it does work I started the car with it off and the idle whent constantly from 1100 to 1200 RPM in a very annoying constant way, and with it on it does the usual 1000-1400 RPM jump.
-I didnt have the proper grounds at first and the electricity running thru my coolant was 22.-- with the car on. Added a valve cover ground, the one near the power steering, the radiator .Now I get about 2.-- with the car on.I havn't flushed the system, could the rest just be electricity running thru the coolant that needs to be flushed???
-I have no Exhaust O2 sensor
-Cleaned the valve just right of the IACV and tightened it down all the way.
-Sprayed a can of carb cleaner around all the valves on the mani, were it connects to the head, and on the vacumes that connect to the head.
So does any one have any clue on what it could possible be??? Thanks alot for your help!!!
