I took advantage of the Honda Car Care Month free car inspection and was quoted for the following repairs:
I'm thinking that I can replace the valve cover gasket - though it was replaced only 19K miles ago (4 years ago), and the distributor shaft seal myself - they're both straightforward from what I understand? The mirror is easy (I've been looking for a new one). The air filter is a laugh, since I just replaced it 2 months ago.
What about the front axle seal and front axle? Are either of these safety issues, or can I drive it until they fail? I presume that if the axle fails, it will either seize or fall out, either of which would be a problem?
For what it's worth, I drive about 250 miles a weekend, but only on the weekend, and entirely highway miles. Thanks for the advice!
Recommendations:
Rt Axle Seal Leaking
Rt frt axle internal failure
Valve cover gasket leaking
Distributor Shaft Seal Leaking
Rt Mirror Damaged
Air Filter Dirty
Rt Mirror Damaged
Air Filter Dirty
