I just got a new motor for my window since the othe went out and I re assembled the window. now it works but as the window goes up, it tilts forward and does't seal correctly leaving a slight opening in the back letting air in. how can I fix it?
Driver window problems
Hey meng I just did this yesterday on my DS window.
O------OO-----O----O------O
This is what the bolt pattern is like ya know. The first bolt on the left is the adjustable one. This bolt will let you adjust the window so when you roll it up it doesnt go forward. I would also check and make sure that the window is inside the track on the weatherstrip. even if its off a little bit it will skew the way the window goes up.
PM me if you have any q's. Like I said i worked on this last night so its still kinda fresh!
Paul
Sold, but not forgotten.
Mine did the same thing.
The fix? Silicon Lubricant.
Spray down in your run channels. Your run channels are what holds your window in place. Spray down in the run channel by your rear view mirror, and by the door handle on the outside.
For better results, use alot, and spray along your window channels aswell. This fixed my problem.
Hope this helps.
:::Jeremy
[ My Car Domian ] - [ My Members Ride Thread ] - [ Facebook ]
My Top CB7Tuners :
TypeG
aww_shiet
91accordexr33
[QUOTE=bacal36]Hey meng I just did this yesterday on my DS window.
This is what the bolt pattern is like ya know. The first bolt on the left is the adjustable one. This bolt will let you adjust the window so when you roll it up it doesn't go forward. I would also check and make sure that the window is inside the track on the weatherstrip. even if its off a little bit it will skew the way the window goes up.[QUOTE]
You got to listen to this guy! All the rest is BS. spraying all that junk is not going to help. Take the panel off (remember to be super careful with the white door handle clip) and then realign the window. You may need some small wires to connect the power to the switch so you don't keep needing to put on take off panel each time you check.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
[QUOTE=SilverShadow][QUOTE=bacal36]Hey meng I just did this yesterday on my DS window.
Spraying the lubricant in the run channels frees up any dirt or grime that the window might have lodged up in there after months and months of use. Thus causes the run channels to pretty much "grab" the window when rolling up.
Any easier way to check if it's the run channel's, is to hold your hand on the window area where it leaves gap. Roll it up, and keep the window pressed against the run channel. If your window doesn't leave a gap after doing this, your run channel's are dirty.
I've done this, and it worked for me flawlessly. However, if this doesn't work for him, then maybe he would have to try and re-assure some bolts.
Just giving him the easier way, before he attempts the harder way. It wouldn't hurt to try.
:::JeremyLast edited by LordXaero; 03-30-2007, 11:47 PM.
My Top CB7Tuners :
TypeG
aww_shiet
91accordexr33
ok...that's true. Process of elimination works best,easier to harder also. But if the windows are tinted, be careful not to get the spray on it or tint will peel off.
Originally posted by SilverShadowok...that's true. Process of elimination works best,easier to harder also. But if the windows are tinted, be careful not to get the spray on it or tint will peel off.
:::Jeremy
My Top CB7Tuners :
TypeG
aww_shiet
91accordexr33
Originally posted by wrichards2005Make sure you do both. Spray the lubricant AND re-align it. Mine was aligned right, but I let it sit and it dried out. My window actually got caught up and BENT my brand new track. FUCKING EBAY!!!R.I.P. CB7; hello spec-v!
Member's Ride
FS thread: full part-out
Help me with my spec-V fund, buy my stuff!!!
Degree of rice and performability are inversely related.
