My E-Brake light will not go off. The handle is all they way down and the connector that plugs into the E-Brake is VERY connected. I've tried pulling it up and letting it down repeatedly and nothing happens. Someone help. And no one ver responds to my posts, so to make me feel better, if no one knows how to help, at least just say "HI".
E-Brake light stays on
My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!Tags: None
its not an "ebrake light".. its simply a brake light.. could be a burnt out bulb, PARTIALLY burnt out bulb, low brake fluid, malfunction with brake light wiring, etc..
check all your bulbs about 3 times to make sure, then check your fluid level.. if either one of those isnt the culprit, not sure what to tell you..
Originally posted by BlackAndTan
this happened to me before in a crx i used to have, and it just meant it was low on brake fluid. probably the same on accords.Originally posted by fizzbob7 i think the "jdm everything" craze is funny........it's the same thing, a fad.......and an overpriced one at that
Originally posted by uncle_el believe it or not, this forum is not about you or your post count. it's about providing relevant information and exchanging it with one another, in order to help build a community. if you don't like that, please leave.
Well, I'm just going to try to add brake fluid and see what happens as I recently did a brake job. But I don't get it...how is that light not an e-brake only light? There's a connector on the bottom of the e-brake that sends a signal to the light.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
i dunno either, its kinda of like the "S" for the sport shift on the automatics, it also is a kind of check light for other things such as a bad speed sensor
all of those lights have other functions besides the obvious, just the way honda made 'em, keep us updatedOriginally posted by fizzbob7 i think the "jdm everything" craze is funny........it's the same thing, a fad.......and an overpriced one at that
