i have a 91 lx will an 91 se ecu add hp or anything top speed
    i have a 91 accord lx i want to get a 91 se ecu will it increase hp or tourque or top speed
    lx has 125
    se has 140
    mods i have is 2 1/4 downpipe high flow cat bullet cat backsystem
    tayler wires,ngk spark plugs,comp cam and short ram intake
    sinse i have these mods will it increase the hp a little
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    Just the ECU itself isn't gonna do a damn thing, unless you get the split port exhaust manifold and dual runner intake manifold from the A6 as well.
    00 Jeep Grand Cherokee 4.7 V8 4X4
    92 Honda Accord LX
    95 Honda Civic CX
      Don't forget the higher volume A6 fuel pump too.
      Keep in mind that the 125 hp is flywheel and its acutally only about 100-105 hp thats actually getting to the ground.
        Ah...yes, thank you....forgot about that. 40psi vs 36psi
        92 Honda Accord LX
        95 Honda Civic CX
          is it really worth the a6 fuel pump.i reall dont see the need for it.
            Well, Honda obviously saw a need for it, and they engineered the car. Probably because the A6 draws in alot more air than the A1/A4 when the butterfly valves open, and with more air you need more fuel so it doesn't lean out.
            92 Honda Accord LX
            95 Honda Civic CX
              when my a4 ecu was swapped out for the a6 ecu that is the 91 se or 92 93 ex or se i felt a difference, but of course u have to have the right stuff to run it, like the things that are in the 92 93 se ex or 91 se car, like header, intake manifoold etc
              if not then it wont do anything.
              Retro!
              Hater
                Ummm....I was doing a little research by myself and the fuel pumps between all CB7's look to be the same. It is the fuel pressure regulator that is different among F22a1/a4 and F22a6, thus causing the higher fuel pressures. Also, the fuel injectors are the same.
                Don't forget the camshafts are different on the A6. and WHY would you want to get to F22a6 specs anyways?!?!
                You can do better if you save a little more $$$.....plan people plan!!
                  i got my a6 parts cheap thats why.everythnig i need for $20 bucks.why wouldnt i swap it out for that price.
                    yeup, good advice, get some bigger things like turbo hehe..i just got my stuff for cheap so i did it =)
                    Retro!
                    Hater
                      Is it? hmmm....you know you may be right.
                      92 Honda Accord LX
                      95 Honda Civic CX
