the car starts up fine and everything i just startd trying to get it used to being started and driven since it was off the road for a while
serviced fine all fluids good and all that jazz
but when i would actually start to drive it, it just gets to a certain point and shuts off completely
try to start it back up. starters working good, everythings turning over good. it just wont start. i give it a little time and it starts again, and the process starts all ovver
i was in my driveway a few minutes ago and had it started up and warming up. i reved it up a tiny bit and it was fine. did it again and the car just shut off then decided to not start up again. this looks fimiliar
its a 10th ae automatic f22, no mods bu i/h/e
anyone have any ideas at all???
i know its not overheating. i have new fans and since then the needle hasnt moved past halfway and engine heat is fine. im just..boggled
edit::
i went ahead and repladcfed the fuel fileter since its been a long time since its been changed. wnet ahead and filled it up with high octane and some seafoam
the car would start for about 10 minutes
we checked in the fuel filter and on the fuel rail and the car wasnt getting fed any gas at all, the spark was fine and dandy though.
so we're like trying to think of what would cause the car not to get gas.
main relay and fuel pump are what im guessing. but doesnt the main realy go in correlation with working the fuel pump?? main relay is my next target now
and about the coil/igneiter thing.. would that have to do with this? idk if i should be worried about that
im just trying to get all the help i can get right now, thanks for the advice so far. who has advice for my next phase of troubleshooting??
then i went to my thrusday night bowling league
came home about a ahalf hour ago
cranked it once..nothing..twice. started right up
drove it up and down the road a few times. drove fine. turned it off and started it back up two tiems in a row to see if it would, and it did.
edit::
