has anyone removed there a/c system? i want to remove mine but im curious as to the dangers and what not by doing this myself. also if u have what size belt will i need to get? i've searched and cant find anything.
A/C removal
Search. The dangerous part is removing the freon thats it. Take it to a shop to get that shit drawn out. Then the rest is self explanatory.
I don't see why it's "not legal" as long as nobody sees you draining the freon into the atmosphere, but if you still have freon in the system do the planet a favor and have it removed at a shop. As far as "a bucket" approach it's mostly a gas, so that's out of the question.
However; if you're system if long drained of any freon you just remove the compressor and any lines going from it, super easy, I did it on my coupe and removed a ton of weight that was completely useless.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
when asking for the belt, just say u need a alt. belt with no a/cProject M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
Originally posted by TorqstrI don't see why it's "not legal" as long as nobody sees you draining the freon into the atmosphere, but if you still have freon in the system do the planet a favor and have it removed at a shop. As far as "a bucket" approach it's mostly a gas, so that's out of the question.
k cool. im pretty sure i have very little freon left in there. it blows cool not cold.
Anyone feel a difference in performance?
not very noticableProject M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
is there anything i need to know before removing the ac and all the lines? i've read the haynes manual for removing most of the parts but it doesnt say anything bout what will happen if i dont hook it back up. it assumes im replacing it not removing it. are there any electrical parts that i need to be aware of in removing the entire system?
nothing will happen...just buy a belt with no a/c.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
First off, why would you want to remove the A/C system?
Either way, DO NOT open the system if it still contains freon! The second you pull off or cut a line that gas will explode out. Take it to a shop and have it evacuated properlly. Hell...freon is worth so much money these days, they might even pay you for it.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Both have gone up in price within the past year.
Originally posted by mrhondaFirst off, why would you want to remove the A/C system?
ok I removed the easy lines and what not. how do i get the ones out from the firewall. im having trouble removing the black plastic box behind the glove box.
would it be bad to run the engine with the lines detached with the compressor still hooked up to the pulley?Last edited by VBaccord24; 04-12-2007, 07:11 PM.
