i was driving to work one day while i was slowing down it was trying to die and my car just completly shut off on me. Later that day i tried turning it on again and it was on but lasted a couple of seconds and dies again. I was thinkn could it be the fuel pump or something else any idea?
car wont stay on wat could it be?
So mainly its your fuel and ignition system. Id check for alotta things does your fuel pump prime up and all check your ,distributor fuel pump and last but not least whens the last time have you given yourself a tune-up cause ive heard a similar problem like this and it mainly led to 1)ignition module 2) fuel relay 3)fuel filter 4) distributor.
also does ur car start again after it shuts off????are we there yet are we there yet are we there yet
i forgat to say this too.
it might be the egnition swich but the electrical part of it. it happen on my accord. as soon as i started the car and let go of the keys the car would shut off. then i had to keep my keys on a certain position in order for my car to stay home. but as the guys said it might be the other stuff. just do a full tune up. that won't hurt u. start with the fuel filterare we there yet are we there yet are we there yet
things to check....
main relay number one thing.
if this doesnt work.
second, listen to the fuel pump when u turn the key to ON
cant be ur timing or anything (like mines was) sense ur car starts.
check or change plugs
battery terminal.....
im tryna give u everything to check put its hard if im not actually there.
alternator, theres a lot of things it MIGHT be.
but i would first check the main relay, or get a new one, because if it just started doing this it might be that, seems like there going out alot around this time of the year.NEED RAP BEATS.....
www.soundclick.com/akcidentaltrakz
